Connection between two different networks without NAT
I want to connect the two networks through checkpoint and cisco 3750. Currently, several other networks in the organization (video conferencing, IP telephony  traffic to servers in  DMZ, etc.) are routed through cisco 3750.
I have made the scheme shown in a picture with two laptops to test.
This scheme should work, but I don't know why it doesn't work.
Can you help me!  Where I am wrong?
Checkpoints rules:
source 10.0.0.0/22 destination 192.168.100.0/24 any service accept
source 192.168.100.0/24 destination 10.0.0.0.22 any service accept
А very unexpected problem, but it has already been solved. thanks to everyone who wrote here.
10 Replies 10
Deepak Kumar
As I am understating that Route at Core switch (3750) is having an issue as:
Try with a new route: ip route 10.0.0.0 255.255.252.0 192.168.97.1
As Checkpoint is a reply for the ping then I can assume that checkpoint having correct routing and rules configuration. But you can below things on the checkpoint also (Sorry not expert in checkpoint so can't explain correct configuration):
Route for: 10.0.0.0/255.255.252.0
The rule for traffic allow for this subnet also.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I try the new routing, the result is the same.
One  thing I cannot understand?
How I can  ping from laptop with address 192.168.100.149 address 192.168.97.4  but I can't ping  192.168.97.1
Because your checkpoint is not having routes or policy.
https://dl3.checkpoint.com/paid/79/7916511f80908c3056af526bae304602/CP_R77_Firewall_AdminGuide.pdf?HashKey=1570100926_4c303b2df5acddbfad6dd4ea5c01563c&xtn=.pdf
Deepak Kumar,
I have on checkpoint:
routing   destination 192.168.100.148 /255.255.255.252 gateway 192.168.97.4
rules
source 10.0.0.0/255.255.252.0 destination 192.168.97.0/255.255.255.0 any services accept
source 192.168.97.0/255.255.255.0 destination 10.0.0.0/255.255.252.0 any services accept
source 10.0.0.0/255.255.252.0 destination 192.168.100.0/255.255.255.0 any services accept
source 192.168.100.0/255.255.255.0 destination 10.0.0.0/255.255.252.0 any services accept
source 192.168.97.0/255.255.255.0 destination 192.168.100.0/255.255.255.0 any services accept
source 192.168.100.0/255.255.255.0 destination 192.168.97.0/255.255.255.0 any services accept
did you remove:
ip route 10.0.1.208 255.255.255.252 192.168.97.1
before adding:
What is the configuration of the 3560 ?
how are the sync interfaces between both Checkpoints configured ? If you use a layer 3 switch for connecting them both, you need to make sure that the ports are 'switchports' and not routed ports...
Checkpoints are in cluster with Checkpoint smart-1 5. cluster Mode High Availability
This is configuration on cisco ports:
interface Vlan97
 description "To Core CheckPoint"
 ip address 192.168.97.4 255.255.255.248
interface GigabitEthernet1/0/20
 description "To Core 01 CheckPoint"
 switchport access vlan 97
 switchport mode access
 spanning-tree portfast
interface GigabitEthernet1/0/22
 description "To Core 02 CheckPoint"
Hi, try checking out if any implicit NAT is configured on the interfaces, i had a similar issue once and that was the issue.
I checked, there is no NAT on the interfaces of Core Checkpoints.
I have two Core Checkpoints in cluster, transport network to the boarder CheckPoint where are NAT polices for internet access .
Currently network 10.0.0.0/22 communicates with network 192.168.100.0/24 through a border checkpoint with NAT.
I want to eliminate the connection through border checkpoint and connect the networks directly with routing over Core checkpoint.
These are the  firewall rules on Core Checkpoints and Border Checkpoint
These are the  NAT rules on Border Checkpoint
Source 10.0.0.0/22 destination 192.168.95.0/24 NAT 192.168.95.2
Source 10.0.0.0/22 destination 192.168.100.0/24 NAT 192.168.95.2
I can not understand what is happening!!!!
Routing table on Core CheckPoint:
Vlan 97 on Cisco 3750,  Lan 192.168.97.0
Destination                        Netmask                             Gateway             metric   Interface
192.168.97.0                      255.255.255.0                                                       0           eth6
192.168.100.148               255.255.255.252               192.168.97.4                0           eth6
Eth6 > 192.168.97.1  ( cluster address)
Routing table on Border CheckPoint:
Vlan 95 on Border CheckPoint, Lan 192.168.95.0
192.168.95.0                      255.255.255.0                                                       0           eth1-02
192.168.100.0                    255.255.255.0                    192.168.95.1              0           eth1-02
Eth1-02> 192.168.95.2
Eth1-02 is physical interface, expansion module on checkpoint
Cisco 3750
interface Vlan95
 description "To Border CheckPoint"
 ip address 192.168.95.1 255.255.255.252
interface Vlan97
interface GigabitEthernet1/0/23
 description TO BORDER CHEKPOINT
 switchport access vlan 95
As you can see everything is the same!!!
 On Cisco > !
interface Vlan100
 ip address 192.168.100.1 255.255.255.0
 description "Test Vlan 100 laptop"
 switchport access vlan 100
What happens when i try a ping from Cisco 3750
Ping to 192.168.97.1 – Yes, ping to 192.168.95.2- Yes
What happens when i try a ping from a laptop with an address 192.168.100.149
Ping to 192.168.95.1 – Yes, ping to 192.168.95.2 ---- YES
Ping to 192.168.97.4 – Yes, ping to 192.168.97.1 ???????? NOOOOO Why??????????? NO
