Connectivity between two sites
Hi everyone, this is probably very simply but I can't seem to figure it out.
I am unable to ping a server at Site B from a server at Site A. The server at Site A is online and reachable from other sites..
Site A server 10.103.0.163
Site B server 10.119.255.69
Traceroute from Site A shows the following:
1    <1 ms    <1 ms    <1 ms  10.103.0.254
  2     *        *        *     Request timed out.
  3    <1 ms    <1 ms    <1 ms  10.123.127.250
  4     2 ms     2 ms     2 ms  10.44.234.89
  5     9 ms     9 ms     9 ms  10.44.73.77
  6     9 ms     9 ms     9 ms  10.44.73.78
  7     9 ms     8 ms     9 ms  10.119.255.2
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
So it looks as though it is failing before the final hop. Site A has a Nexus 9000 as the Core switch. I was suspecting a routing issue but can't see anything obvious.
I've attached the Nexus config, would appreciate any assistance.
THank you
1 ACCEPTED SOLUTION
Re: Connectivity between two sites
Guys. Looking at the Nexus config, do I need to add the following?
ip prefix-list allow2redist seq 320 permit 10.119.255.0/20 le 30
vrf context flowerbed
ip route 10.119.255.0/24 10.123.126.226
2 REPLIES 2
Just an additional note. Ping from Nexus:
001# ping 10.119.255.69
PING 10.119.255.69 (10.119.255.69): 56 data bytes
ping: sendto 10.119.255.69 64 chars, No route to host
Request 0 timed out
Content for Community-Ad
July's Community Spotlight Awards
