04-17-2013 06:12 PM - edited 03-07-2019 12:53 PM
I have 4 Pairs of Alcoma radio links connected to a 2960 switch at both ends. I configured Etherchannel on the 4 ports at both ends. The Links are up and running. Inorder to monitor these radio link to know when any of these links fails, native VLAN was assigned to these ports which the radio links are connected. With this, I discovered that I can only ping a pair of these radio links and the remain 3 pairs of radio links could not be reached via ping. Once the active pair is disconnected, another pair becomes reachable. I need to monitor these radio links to ensure they are up at all times. Can any body profer solution to this?
Below is the ports configuration on both ends
interface Port-channel1
switchport trunk native vlan 100
switchport mode trunk
interface FastEthernet0/3
channel-group 1 mode desirable
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
04-18-2013 02:21 PM
You need to look at how these device are configre, which addresses, etc.
04-22-2013 06:31 AM
The Radio links are just pure bridging IP addresses on them are just for management they are on 10.10.10.64/28
The Gateway is on a router subinterface which is .65, Swtich is .66 First pair of radio is 67 and 68, second pair is 69 and 70 third pair is 71 and 72, fourth pair is 73 and 74 while the far end switch is 75. All the radios are configured with gateway of .65.
