Consolidated configuration guide for Catalyst 3850
paul.gordon
Hey Cisco,
Can I please request that you produce a single, consolidated Configuration Guide PDF and Command Reference PDF for the Cisco Catalyst 3850, just like you do for the Catalyst 3750X?
It's pretty annoying having to download 50 different smaller PDFs for the 3850, and even then there appears to be bits missing, such as MSTP, HSRP, etc.
Thank you!
Paul
8 Replies 8
As you can see those links only contain mini-PDFs. I'm looking for one, complete PDF with everything in it.
It's missing because HSRP is not supported (as of yet).  Refer here.
As leo listed these are  the config guides only ones availabe as of now.
There is no consolidated config availabe for this model now.
Inayath.
I'm suprised that HSRP is not supported yet, as I thought this would be one of the most common features required by customers?
I've got a strange feeling that the next software release will include HSRP support and increase the switch stacking feature from four to nine.
Next software release will be April 2013, I think.
Let's hope so... thanks for that Leo.
