Controling test-lab?
Hello everyone,
I'm searching for a productive way to control the Test-lab.
in the lab there are many devices. switches, routers, Wlc ....etc
What I'm searching for is . for ex, after finishing our test, re-back to the previous-config. any Cisco software or ... ? any recommendation ?
Many thanks
Hi  Muayyad,
Do you want to revert back to the original base config? If yes, you can deploy original config and archive it as a first step. Then you can revert back to it anytime manually or after timer expires.
HTH,
Thank you for your reply.
yes, that exactly what I want, but because there are many racks, and more than 200 devices, I'm looking for something more centralized, prodactive. I've already saved the config in flash to revert it in case something happen.
For Cisco tool i can think of Prime or Cisco CNA. There other third party software that you could use or you can actually script it and do it from a server that has access to every single device. Or you can send the command through SNMP.
Can't think of anything else.
HTH,
Thank you again. I already have prime connected to these devices, but that software doesn't provide what I asked for. Also CNA I'm not totally sure it'll provide that as well.
