Converssion to VSS
mostafa ouamou
I have two C6509-E with Sup2T. I converted each one to VSS mode separately.
I want to know the impact or what will be happen if i connected them through the VSL.
The configuration file " Interface numbering" in the both device is not synchronisate yet.
Switch-1>show switch virtual role
RRP information for Instance 1
Valid  Flags   Peer      Preferred  Reserved
               Count     Peer       Peer
TRUE    V        0           0          0
Switch  Switch   Status      Priority     Role     Local   Remote
        Number               Oper(Conf)            SID     SID
LOCAL   1         UP         110(110)     ACTIVE    0       0
Switch-2>show switch virtual role
               Count     Peer       Peer
TRUE    V        0           0          0
LOCAL   2         UP         100(110)     ACTIVE    0       0
5 Replies 5
once connected through VSL, one of the switch virtual roles will be active, the other standby. Check this post, it has a pretty comprehensive overview of what you will get:
https://supportforums.cisco.com/document/124626/virtual-switching-system-vss-configuration-cisco-4500-series-switches
thanks for your response,
Both switch are configured as vss but they never synchronize the configuration so one of them is in production I want to know if I activate the VSL which one will be reload and which config will be override,
Thanks.
When you configure the VSS domain, you can specify which switch becomes the active and which the standby. The one with the lower priority becomes active:
6509SW1(config-vs-domain)# switch 1 priority 110
6509SW1(config-vs-domain)# switch 2 priority 100
6509SW2(config-vs-domain)# switch 1 priority 110
6509SW2(config-vs-domain)# switch 2 priority 100
The configurations don't really matter, as they will be synchronized and reduced to a basic set of commands:
--> When you configure VSL, all existing configurations are removed from the interface except for specific allowed commands. When you configure VSL, the system puts the interface into a restricted mode. This means that only specific configuration commands can be configured on the interface.
The following VSL configuration commands are inserted automatically on all VSL member ports:
•switchport mode trunk
•switchport nonegotiate
•no lldp transmit
•no lldp receive
•no cdp enable
•service-policy output VSL-Queuing-Policy
In VSL restricted mode, only these configuration commands are available:
•channel-group
•default
•description
•exit
•load-interval
•logging
•no
•power
•shutdown --<
The both switchs had already converted to vss but are not synchronized each one had its new interface numbering switch 1 (gig 1/1/1) swich 2 (2/1/1) therefore the switch 1 is in production am afraid that when I connect the switch 2 its config override that of in switch 1.
You really need to add switch-2 during an outage window, as after connecting it you may have to reboot both chassis to sync the config and have switch-1 as active and switch-2 as stand-by. Also, before adding swtch-2 make a good back up of the config in case something goes wrong.
