CPU High utilization over 4500
Varun K S
Frequent Visitor
Frequent Visitor
Hi All
Any suggestion
for the below logs found over 4500 , also CPU utilization is over 95%
Mar  9 08:52:10.857: %C4K_IOSIPROUTEMAN-3-ADJMANNOMOREADJS: AdjMan: hardware adjacency resources exhausted, performance may be degraded.
.Mar  9 08:52:39.276: %C4K_IOSIPROUTEMAN-3-ADJMANNOMOREADJS: AdjMan: hardware adjacency resources exhausted, performance may be degraded.
IPv4 CEF is enabled and running
VRF Default:
83179 prefixes (83179/0 fwd/non-fwd)
Default network 0.0.0.0/0
Table id 0, 0 resets
Database epoch: 0 (83179 entries at this epoch)
Why the utilization is increasing.. is there any method to reduce the utilization without clearing the adjacency and cashe.. is there any other resolution...
Varun
Eugene Lau
Hi Varun,
There was a good discussion here
https://supportforums.cisco.com/thread/26938
A route pointing to an directly connected interface would cause such an issue.
Example
ip route x.x.x.x y.y.y.y 10.1.1.1
or
ip route x.x.x.x y.y.y.y [interface]
Eugene
