CPU utilization High on Cisco 6500
smartboy2255
HI all,
CPU utilization of Switch found as 90-95 % after converting switch from CAT OS to IOS...PLs find details below..
IOS :s72033-ipservicesk9_wan-vz.122-18.SXF17.bin
Model : Cisco 6509E
SUP-SUP720-3B with MSFC3
sh processes cpu
CPU utilization for five seconds: 97%; one minute: 99%; five minutes: 94%
PID       5Sec    1Min     5Min Process
1         0.1%    0.6%     0.7% kernel
3         0.0%    0.0%     0.0% qdelogger
4         0.0%    0.0%     0.0% devc-pty
5         0.0%    0.0%     0.0% devc-mistral.proc
6         0.0%    0.0%     0.0% pipe
7         0.0%    0.0%     0.0% dumper.proc
4104      0.0%    0.0%     0.0% bflash_driver.proc
12297     0.0%    0.0%     0.0% pcmcia_driver.proc
12298     0.0%    0.0%     0.0% mqueue
12299     0.0%    0.0%     0.0% flashfs_hes.proc
12300     0.0%    0.0%     0.0% dfs_bootdisk.proc
12301     0.0%    0.0%     0.0% ldcache.proc
12302     0.0%    0.0%     0.0% watchdog.proc
12303     0.0%    0.0%     0.0% syslogd.proc
12304     0.0%    0.0%     0.0% name_svr.proc
12305     0.0%    0.1%     0.1% wdsysmon.proc
12306     0.0%    0.0%     0.0% sysmgr.proc
16386     0.0%    0.0%     0.0% chkptd.proc
16403     0.0%    0.0%     0.0% sysmgr.proc
16404     0.0%    0.0%     0.0% syslog_dev.proc
16405     0.0%    0.0%     0.0% itrace_exec.proc
--More--                           PID       5Sec    1Min     5Min Process
16406     0.0%    0.0%     0.0% packet.proc
16407     0.0%    0.0%     0.0% installer.proc
16408    77.7%   85.5%    79.4% ios-base
16409     0.0%    0.0%     0.0% fh_fd_rf.proc
16410     0.0%    0.0%     0.0% fh_fd_oir.proc
16411     0.0%    0.0%     0.0% fh_metric_dir.proc
16412     0.0%    0.0%     0.0% fh_fd_snmp.proc
16413     0.0%    0.0%     0.0% fh_fd_none.proc
16414     0.0%    0.0%     0.0% fh_fd_intf.proc
16415     0.0%    0.0%     0.0% fh_fd_counter.proc
16416     0.0%    0.0%     0.0% fh_fd_gold.proc
16417     0.0%    0.0%     0.0% fh_fd_cli.proc
16418     0.0%    0.0%     0.0% fh_fd_timer.proc
16419     0.0%    0.0%     0.0% fh_fd_ioswd.proc
16420     0.0%    0.0%     0.0% fh_server.proc
16421     0.0%    0.0%     0.0% fh_policy_dir.proc
16422     0.0%    0.0%     0.0% ipfs_daemon.proc
16423     0.8%    1.0%     1.2% raw_ip.proc
16424     0.0%    0.0%     0.0% inetd.proc
16425     6.2%    2.3%     2.9% tcp.proc
16426     7.0%    5.7%     6.7% udp.proc
16427     1.9%    1.5%     1.6% iprouting.iosproc
16428     1.3%    1.1%     1.2% cdp2.iosproc
IOS-base process is taking more than 70% of CPU. pls explain IOS-BASE process .PLs share your advice on this issue..
Ajith
Reza Sharifi
Ajith,
I noticed, you are running a modular IOS.  If you use a non-modular IOS, it will most likely change the CPU utilization.  It is also recommended to run non-modular. Also, you release version is pretty old. 12.2(33)SXI5 is the latest
Thanks Reza,  I will check it and update..one more
thing I want to know more about IOS-BASE process..if you have any documents or
links pls share it..One more thing is there any Cisco
document which recommending non modular IOS..
Thanks in Advance..
Ajith
Ajith,
document which recommending non modular IOS..>
There is no official document or I have not seen one, but according to Cisco the next major IOS release for 6500 will not have modular version any more.
Reza
