11-30-2014 08:56 PM - last edited on 03-25-2019 04:31 PM by ciscomoderator
Hi all
I have a Questions from CRC issues.
I heard CRC issue is a layer 1 trouble, so I changed optical cord, SFP and moved another port.
so i grab a CRC issues in this time, I don't know what can i do troubleshooting for CRC issues.
finally, I will upgrade IOS version, i choose IOS version yet, is this correct IOS version use upgrade?
Chassis : Cat 6509-E
Supervisor Module : WS-SUP720-3B
Linecards : WS-6724-SFP and WS-6724-TX
Origin IOS version : sup-bootdisk:s72033-ipservices_wan-mz.122-18.SXF10a.bin
Upgrade IOS version : s72033-ipservices_wan-mz.122-18.SXF17a.bin
Connected Devices : C2960 Series Switch also grab a CRC issues.
If you grab a incorrect informations and suggestion IOS versions, please reply to me.
thank you
Best Regards.
From. Sean Kang
11-30-2014 09:18 PM
Hi Sean,
I dont think, you need to upgrade the IOS for CRC error . CRC is most likely Layer 1 issue .
Layer 1 issue means -- it involve below things .
Switch --GBIC--Cable ---patch panel -- cable-- GBIC --switch .
IS the devices connected directly or thr' patch panel .
Did you replace the GBIC and cable both side.
I would do below thing to narrow down the issue.
1. Change GBIC , cable, patch panel port both side.
2. Move the one side switch port.
3. If the issue not resolved then other side also .
Hope above things will help to narrow down the issue.
VS.Suresh.
*Plz rate the usefull posts *
11-30-2014 09:29 PM
Hi .Suresh
Thanks for your help.
Cat 6509-E connected Between Cat 2960 switch directly.
I move another port, (origin port : gi 1/8 -> new port : gi 1/17) it's same result.
Tried : change optical cord and SFP, and coldboot 2960 switch
Cat 6509==SFP======direct connect====SFP==2960 Switch
what can i try to another actions clear CRC issue?
TQ
Best Regards.
From Sean Kang
11-30-2014 10:01 PM
Hi Sean,
Can you please give below output
show run inter gi x/x (both side switch interface)
show inter gix/x | in up|load|rate|err (both side in 3 times in 2 mins internal)
Thx
