CS-ECR
moaung_sg
Hi... Does anyone tried Cross Stack Equal Cost Route? is there any best practice?
Aung
Ganesh Hariharan
Aung
Hi Anug,
The Cisco StackWise interconnect technology is designed with two       counter-rotating paths of 16 Gb each. In order to efficiently load balance       traffic, packets are allocated between these two logical counter-rotating       paths, which creates the 32-Gb interconnection. There are dual paths from any       port to any other port within the Catalyst 3750 stack. Therefore, maximum       uptime is ensured because there is always an alternate path available if a       failure occurs in either path. The Catalyst 3750 supports:
  • Cross-stack EtherChannel
  • Cross-stack UplinkFast (with subsecond failover)
  • Cross-stack equal cost routes across different switches in the           stack
Check out the below link for more details
https://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00806cb982.shtml
Hope to help !!
Ganesh.H
Remember to rate the helpful post
