11-28-2021 02:03 PM
I have a test lab with 2 switches, both installed from scratch, all default.
Switch A - MAC 0026.xxxx.xxxx, switch prio 32768, unchanged
Switch B - MAC 0022.xxxx.xxxx, switch prio 32768, unchanged
"sh span" shows me that the Root bridge is B, which is correct.
SwitchB#sh span
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 32769
Address 0022.xxxx.xxxx
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Fa0/7 Desg FWD 19 128.8 P2p
After activating mst ONLY on Switch A(no other change in between), Switch A became Root bridge.
SwitchA#sh span
MST0
Spanning tree enabled protocol mstp
Root ID Priority 32768
Address 0026.xxxx.xxxx
Bridge ID Priority 32768 (priority 32768 sys-id-ext 0)
Fa0/7 Desg FWD 200000 128.8 P2p Bound(STP)
SwitchA#
SwitchB#sh span
VLAN0001
Cost 19
Port 8 (FastEthernet0/7)
Aging Time 300
Fa0/7 Root FWD 19 128.8 P2p
SwitchB#
I was surprised until I saw in the pcap traces(see attachments) that on switch A the vlan id is 0, not 1 like on Switch B; this means that the bridge priority on Switch B was indeed 32768 and on A was 32769. In this case seems logical that Switch A becomes root.
I just wanted to know if this is a normal behavior and to have a confirmation that CST always runs with vlan id/sys ext id =0.
thanks
Lucien
03-23-2022 07:56 AM
Hey Lucien,
Initially when both switches were using PVST (acting like CST by default), the bridge ID is bridge priority + vlan (sys ext id). So both switches will use 32769 (32768 + 1) for the PVST instance for VLAN 1.
Now when you converted SwitchA to MSTP, MSTI 0 is created. MSTI 0 is a special STP instance called Internal Spanning Tree and is used to provide info about the other MSTIs via BPDUs. MSTI 0 is what is shown in the pcap. MSTP bridge ID is the bridge priority + MST instance. So, SwitchA will have bridge ID 32768 (32768 + 0) once configured for MST.
Hope this helps clarify what you're seeing in the pcap.
