03-10-2022 05:58 PM
Does the below module from 6807 support single-mode SFP, and no which module supports it?
If yes, is there any limitation?
NAME: "Chassis 1 C6800-DFC Distributed Forwarding Card 4 EARL 1 sub-module of 7", DESCR: "Chassis 1 C6800-DFC Distributed Forwarding Card 4 Rev. 1.0"
Solved! Go to Solution.
03-11-2022 08:23 AM
In general, yes. So, for example, if you get a 9300 switch with 4 10Gig fiber ports, you can use 2 Multi-mode 10Gig SFPs and 2 Single-mode.
It all depends on your requirement and the optic you need (multi or single-mode).
03-11-2022 04:08 PM
@bluesea2010 wrote:
C6800-32P10G
This line card can support LR/SR optics.
However, the daughter card is just a "plain" DFC. This means the line card in slot 1 and slot 3 will "downrate" themselves to "keep up" with the processing power of the plain DFC.
03-10-2022 06:00 PM
Give us more info.
This is just a DFC daughter card. What is the actual line card this DFC is attached/installed into?
03-10-2022 06:27 PM
here is the sh module ,is this enough , actual line card means superviser engine ?
sh module
Mod Ports Card Type Model Serial No.
1 20 DCEF2T 4 port 40GE / 16 port 10GE WS-X6904-40G SAL1914CR59
3 5 Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G SAL1913C7TJ
6 40 DCEF2T 8 port 40GE / 32 port 10GE C6800-32P10G SAL202802XR
7 40 DCEF2T 8 port 40GE / 32 port 10GE C6800-32P10G SAL1911B33J
Mod MAC addresses Hw Fw Sw Status
1 84b8.020b.f46c to 84b8.020b.f47f 1.1 12.2(50r)SYL 15.2(1)SY1 Ok
3 503d.e531.64ee to 503d.e531.64f5 2.1 12.2(50r)SYS 15.2(1)SY1 Ok
6 0035.1af5.d2b1 to 0035.1af5.d2d8 1.2 15.1(58r)SYL 15.2(1)SY1 Ok
7 1005.caeb.9e94 to 1005.caeb.9ebb 1.0 15.1(58r)SYL 15.2(1)SY1 Ok
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6K-DFC4-E SAL1914CT9G 1.2 Ok
3 Policy Feature Card 4 VS-F6K-PFC4 SAL1912BWUL 3.0 Ok
3 CPU Daughterboard VS-F6K-MSFC5 SAL1912C1A3 3.0 Ok
6 Distributed Forwarding Card C6800-DFC SAL202802XR 1.2 Ok
6 Distributed Forwarding Card C6800-DFC SAL202601MA 1.1 Ok
7 Distributed Forwarding Card C6800-DFC SAL1911B33J 1.0 Ok
7 Distributed Forwarding Card C6800-DFC SAL1911B21H 1.0 Ok
03-10-2022 07:56 PM
So this DFC is attached to a WS-X6904-40G in slot 1.
The original question is "support single-mode SFP". Yes, it will support SM optics, CFP-40G-LR4 or use a FourX converter to convert the port down to a SFP+ port.
03-10-2022 11:30 PM
WS-X6904-40G - yes this can have : make sure you have right module. as below mentioned document
03-11-2022 06:32 AM
Not clear what you are asking, but all line cards in slots 1, 6, and 7 support single-mode or Multi-mode. Also, the supervisor engine in slot 3 comes with 2 10Gig interfaces that could also be single-mode or multi-mode. It is important for you to know that slots 1, 6, and 7 are all 40Gig modules that can support 10Gig single-mode or multi-mode SFPs with breakout cables.
03-11-2022 07:33 AM
My question is,in my seven and 6 module , I am using multimode sfp, in that same module can I plug single mode sfp
03-11-2022 07:51 AM
Yes, absolutely. You can use single-mode and multi-mode ports using the same line card. Example port 6/1 multi-mode, port 6/2 single-mode, and so on...
03-11-2022 07:55 AM
Even catalyst 9k is also the same?
03-11-2022 08:23 AM
03-11-2022 04:08 PM
@bluesea2010 wrote:
C6800-32P10G
