Data Center need to relocate
nihammimm
I need to relocate one of our data center to other location, We can’t change the existing IP address for relocating.
Could anyone give guidelines for relocating one data center to another location.
andrew.prince
Level 10
Level 10
Either
1) Pick up the data center and move it all in one go - a big bang
2) Build your new DC along side the existing with a new IP Subnet and migrate services over.
HTH>
e-carracedo
We relocated our Datacenter two month ago and we didn't change the Ip Lan.
I give you some topics:
- Check the temperature of de air conditioning. It' very important that this issue it's working properly.
- Verify the electrical instalation and stabilized current it's working properly.
- In order to move the DC without change the IP LAN, you must work at night, shutdown the DC and move to the new location.
There many issues to check and depend the infrastructure, but I think this few items are the most important.
