Dear friends i could not ping one lan to other asa lan but from inside lan i can ping to next hop address from any of asa but i am unable to ping from the lan of one ASA-1 TO lan of ASA-2 please can any one help in this regard.
ASA-1
ASA Version 8.4(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0
nameif outside
security-level 0
ip address 209.165.200.202 255.255.255.0
interface GigabitEthernet1
nameif inside
security-level 100
ip address 30.0.1.1 255.255.255.0
interface GigabitEthernet2
nameif dmz
security-level 30
ip address 172.16.10.1 255.255.255.0
interface GigabitEthernet3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object network INSIDE_LAN
subnet 30.0.1.0 255.255.255.0
description INSIDE-LAN
access-list OUTSIDE-ACCESS extended permit ip any any
access-list OUTSIDE-ACCESS extended permit icmp any any echo-reply
access-list OUTSIDE-ACCESS extended permit tcp any any eq www
access-list OUTSIDE-ACCESS extended permit tcp any any eq https
access-list OUTSIDE-ACCESS extended permit tcp any any eq gopher
access-list INSIDE-ACCESS extended permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
access-group OUTSIDE-ACCESS in interface outside
access-group INSIDE-ACCESS in interface inside
route outside 0.0.0.0 0.0.0.0 209.165.200.201 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect icmp
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 1
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:a37a84ea3c28f1a89e0ab88a907325ea
: end
ciscoasa(config)#
ASA -2
ciscoasa(config)# SHO RUN
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
nameif outside
security-level 0
ip address 209.165.200.201 255.255.255.0
nameif inside
security-level 100
ip address 10.0.1.1 255.255.255.0
nameif dmz
security-level 30
ip address 172.16.1.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object network INSIDE_LOCAL
subnet 10.0.1.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 209.165.200.202 1
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect icmp
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
call-home
profile CiscoTAC-1
  no active
Cryptochecksum:9237c6aac195411cc8198673856511fb
: end
james.doukas
Beginner
Beginner
I think you need inside routes as well as outside routes. I don't think the inside networks know about the networks on the other ASA. I've only worked on old PIX firewalls so things might be different now.
Recognize Your Peers
