Default interface security command
Tom Teunissen
Visitor
I'm looking for a single interface command that sets several commands at once. And I'm not looking for 'default interface ...' or 'interface range ...' because many people I ask think I am revering to those.
I am looking for the command that sets at least 'switchport mode access', 'switchport nonegotiate' and 'switchport bpdufilter' (I think).
As I heard it during a CCNP training, I learned that Cisco reccoments to apply this on access ports. I can't find my notes on that course anywhere, so please advise.
Thanks, best regards, Tom
I tried to skim through my notes and this is the closest I could find.
The other lines must be added manually. Good luck with CCNP!
10 Replies 10
ciscoamit_497
Level 4
Level 4
Hi Tom,
I didn't get you clearly, but on the behalf of my understanding,
Please refer to below links that may be help to u---
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/19ew/configuration/guide/port_sec.pdf
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/intparam.html
Hope, This been informative to u..
Thanks.
Amit
*******Please rate the helpful posts********
Hi Amit,
Thanks for your quick response. Though this is not  quite what I mean. I meant one specific cli command (something like  'switchport interface ...' or vice versa). When applied on a defaulted  interface, at least 'switchport mode access', 'switchport nonegotiate'  and 'spanning-tree bpduguard' are applied. It functions as a kind of  macro, but it is part of IOS.
Thanks, Tom
Sandeep Choudhary
Hi Tom,
I am not much aware about exact default coammd to configure all security parameter by 1 deafult command:
The default interface command is a great way to reset an interface to its default configuration. You will need to be in configuration mode in order to issue this command. You can combine default interface with the interface range command on Cisco switches to set multiple interfaces to their default configuration with a single command.
i will try to find out more about this coammnd(if this is avilable).
Thanks Sandeep,
But default interface isn't the command I'm looking for.
Thanks anyway!
Regards, Tom
is this what you are looking for ?
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22ea/SCG/swmacro.html
Regards.
Alain
Hi Alain,
Almost, only the 1 command I am looking for is a part of IOS. So you do not have to configure macro's...
Thanks, Tom
hi tom,
as per my SWITCH notes, i'm not sure whether you're referring to the 'switchport host' interface command.
Switch(config-if)#do sh run int f0/24
Building configuration...
Current configuration : 34 bytes
interface FastEthernet0/24
end
Switch(config-if)#switchport ?
  access         Set access mode characteristics of the interface
  host           Set port host
  mode           Set trunking mode of the interface
  nonegotiate    Device will not engage in negotiation protocol on this interface
  port-security  Security related command
  priority       Set appliance 802.1p priority
  protected      Configure an interface to be a protected port
  trunk          Set trunking characteristics of the interface
  voice          Voice appliance attributes
Switch(config-if)#switchport host ?
switchport mode will be set to access
spanning-tree portfast will be enabled
channel group will be disabled
Current configuration : 82 bytes
end
Hi John,
I guess that must be it. As I remember it a couple more settings were modified, but maybe I remember it wrong.
Thanks!
Regards, Tom
Thanks John!
Best regards, Tom
