08-27-2009 11:31 AM - edited 03-06-2019 07:28 AM
I have two 3550 switches with HSRP and two Vlans, the configuration works fine .The only issue is Vlan1 can access internet with default gateway of HSRP VLAN 1 IP , but vlan 2 doesnt untill I change the gateway to point to PIX firewall.
I have checked there isnt any default route on the switch which seems to be the issue but how come than Vlan 1 access the internet , if thereisnt any route to point to internet. Any idea
08-27-2009 12:28 PM
Can you perhaps post the configuration of your 3550? Also please try to explain in more detail how is your network configured and where is the PIX connected. Your current description does not illustrate your present situation very well. Thanks in advance!
Best regards,
Peter
08-27-2009 01:25 PM
08-27-2009 02:51 PM
Please elaborate more on your current Network design?
1- why you dont have a default route pointing to the pix?
2- To which port the pix is connected on the switch?
3- what is all that BGP config for?
4- why do you have 2 HSRP Groups and what device participating in the HSRP groups?
4- why the ports part of VLan 2 in (dynamic-desirable) mode?
Kindly reply to help you better,
Mohamed
08-28-2009 06:13 AM
Hello Imran,
vlan1 has public address and it is advertised in BGP to the two eBGP neighbors this is enough to allow internet connectivity.
you may be missing a static route for return traffic of vlan2 on the firewall if it is on the middle.
Hope to help
Giuseppe
08-28-2009 12:27 PM
Giue
I was able to see a default route on my configs
ip default-gateway 201.12.1.2
That the IP of PIX Vlan1 , how do i add a route for Vlan2 the VLAN 2 interface for PIX is 201.12.1.130
Also all my servers are connected to this switch as well as the PIX and internet is terminated to this PIX
