Define Network in routing protocol
Eli G.
Hi guys.
I'm studding for CCNA and im at the routing protocols now.
When define which routing protocol i want to use (RIP EIGRP etc), i need to define a network. The router then publish the whole subnet. lets say i have an INT with IP 192.168.1.1/30 so in running config i will see that it publish 192.168.1.0 (as if its class c).
but then i learned that if you want it to publish the exact network i can add 0.0.0.0 at the end of the command (like: network 192.168.1.1 0.0.0.0).
now in running-config i will see that eigrp network is 192.168.1.1 0.0.0.0 AND 192.168.1.1
my question is why is it 0.0.0.0 and not 255.255.255.255
Thanks for your help.
Seb Rupik
Hi there,
It is a wildcard mask:
https://en.wikipedia.org/wiki/Wildcard_mask
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
Thanks Seb. the wiki explained it perfectly.
Thanks for your time.
Cheers :)
Reza Sharifi
192.168.1.1 0.0.0.0
This is the smallest address.
If you try 192.168.1.1 255.255.255.255 in EIGRP or OSPF
They both will still show you 192.168.1.1 0.0.0.0
