description for frame
nnn_sss22
2 Accepted Solutions
Julio E. Moisa
Preamble: consists of 7 bytes, it is used by the receiver in order to enable the bit sync.
Start of Frame: Basically indicates the beginning of the frame
Destination Address: is the Physical Address (MAC Address) of destination
Source Address: is the Physical Address (MAC Address) who originated the frame.
Tag protocol identifier or TPID: As I know it is used to identify the tag of a VLAN. Or distinguisher frames from other frames.
Tag control identifier or TCI: It can be used to prioritize or take action when there is congestion.
Type: indicates the type of data to immediately follow in the Data field
Data: Basically is the information transported to the destination.
Checksum sequence: is the method used to verify the integrity of the frame. It uses (CRC) algorithm to detect transmission errors.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Jon Marshall
Not sure what you mean by what header will the switch add on a trunk port.
The packet format you have posted is for a tagged vlan ie. it is what the packet would look like when sent on a trunk port so there is nothing to add.
Jon
13 Replies 13
Julio E. Moisa
Frame is consist of these things which are below. right?
Destination Address: 6B
Source Address: 6B
Type: 2B
Data: 1500B
Checksum sequence 4B
When Preamble and SFD will attached with the frame? thanks
Jon Marshall
Jon
As Jon notes, what you have listed is a tagged frame, which can support multiple VLANs.  The only kind of trunks that would further add to this frame would be Q-in-Q; tagged frames that contain tagged frames.
BTW, questions like your are often better handled on Cisco's learning network, i.e.: https://learningnetwork.cisco.com/welcome.
If we have only vlan 1 then additional header will not be added.
When this packet cross the trunk port then which header will be add in the trunk port in this frame (for multiple vlans).
If it is a trunk link and the vlan is not the native vlan then the tag will be added to the header.
Jon
yes,if the vlan is not native vlan then these tags will be added which are below.
Total frame size with VLAN Tag is 1530B
Without VLAN Tag, the frame size is 1526 B. right?
The tag is 4 bytes.
So the maximum frame size without a tag is 1518 and with a tag it is 1522.
Jon
Preamble: 7B
Start of Frame: 1B
Source Address: 6B
Tag protocol identifier or TPID: 2B
Tag control identifier or TCI: 2B
Type: 2B
Data: 1500B
when i calculate then it is 1530B with vlan tag and without vlan tag 1526B.
How it is 1522B with vlan tag and 1518B without vlan tag?
The preamble and SFD (Start of Frame Delimiter) are not part of the frame.
Jon
I have read some links even wikipedia. there is mention 1526B and with 1530B
i am also sending you one link
https://networkengineering.stackexchange.com/questions/5057/what-is-the-actual-size-of-an-ethernet-mtu
Please can you tell me if preamble and SFD are not part of the frame then what are these. thanks
If you are talking about the frame you do not include those first two fields.
There is something called Q-in-Q which is generally used by SPs and this involves the use of two 4 byte tags which would increase the maximum frame size to 1526.
I have no idea where the 1530 is coming from.
Jon
Source Address: 6B
Type: 2B
Data: 1500B
