09-04-2024 11:04 PM
Hi all;
Based on Cisco's documents, when using "auto-source" keyword for Device Tracking probilng operation, the following sequence of events occur:
Unfortunately, I cannot understand the second operation. Can anyone explain it with some examples?
Solved! Go to Solution.
09-05-2024 01:04 AM
Yes, using an existing IP in an ARP probe would violate RFC 5227 and could cause issues by confusing other devices' ARP tables, leading to IP conflicts or network disruptions. The sender IP should always be 0.0.0.0 to avoid this.
-Enes
09-04-2024 11:57 PM
hello @rezaalikhani. The second operation refers to the switch looking for an existing IP-MAC binding in the same subnet when an svi isn't available. It checks the Device Tracking table for any known IP addresses and uses one as the source for probing/.
for example:
Let’s say you have devices on VLAN 10 (192.168.1.0/24), and there’s no SVI.
-The switch has learned IP-MAC pairs, like:
That's my understanding of it
-Enes
09-05-2024 12:21 AM
Thanks for your reply;
Based on RFC 5227:
For ARP probes traffic, the endpoint should choose 0.0.0.0 in 'Sender IP Address' field. The 'Sender IP Address' field must be set to all zeroes; this is to avoid polluting ARP caches in other hosts on the same link in the case where the address turns out to be already in use by another host.
Does choosing an existing IP address (possibly from another endpoint) violate the RFC and possibly create problems for the existing client?
09-05-2024 01:04 AM
-Enes
09-05-2024 01:28 AM
I already share doc about this case and You mentioned you check it!!!
MHM
09-05-2024 02:04 AM
Yes, I already checked that document thoroughly... But that document does not point to my question directly.
