DHCP and LAN troubles
plebras
Beginner
Beginner
Hi all and thanks in advance for your help.
I've been experiencing troubles on my LAN for 2 days.
Is it because of my 2 new computers (Dell E5530 / Win 7 Pro)?
Anyway here is the situation:
My DHCP pool is settled on my 3750 stack.
A couple of computers could not get an ip address on the Lan yesterday morning.
I checked on the Cisco 3750 and the DHCP is only half used.
I had to clear a few ip addresses on the DHCP so that those computers could get an address.
As well our Wifi terminals are very slow as they are connected to a 2960 linked to the stack.
Could you help me finding my way out ?
Another question :
I have some excluded addresses on my DHCP (192.168.1.1 to 192.168.1.99)
I would like to change that (so I would only have 192.168.1.1 to 192.168.1.79 excluded).
Would you explain me what I should do ?
Thanks very much.
Phil
devils_advocate
Rising star
Rising star
Hi Phil
Can you post your config with the usernames/passwords and any sensitive information removed?
Hi devil,
thanks for your interest in my problem.
I wanted to send it yesterday but it wouldn't work.
I found out what was going on with my DHCP: the conflict database was full!
I deleted some of the addresses which had been for a long time disabled and now the DHCP works fine.
Hi Philippe.
For your first question, as suggested, post a show run of your 3750.
For your second point, no ip dhcp excluded-address 192.168.1.1  192.168.1.99
ip dhcp excluded-address 192.168.1.1  192.168.1.79
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Thanks Carlo for excluded addresses.
Sure you wan to see a full show run? Well here it is.
! Last configuration change at 10:56:18 WET Thu Oct 24 2013 by plb
! NVRAM config last updated at 16:59:00 WET Wed Sep 25 2013 by plb
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname switch01
logging buffered 1000000 debugging
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxx
username plb secret 5 xxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone WET 1
clock summer-time WET recurring last Sun Mar 3:00 last Sun Oct 3:00
switch 1 provision ws-c3750e-24pd
switch 2 provision ws-c3750e-24pd
switch 3 provision ws-c3750e-24pd
switch 4 provision ws-c3750e-24pd
system mtu routing 1500
ip subnet-zero
ip routing
ip domain-name xxxxxxxxxxxxx.lan
ip dhcp excluded-address 192.168.1.220 192.168.1.254
ip dhcp pool LAN_OLD
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   dns-server 10.56.4.105
   lease 0 18
ip dhcp pool n*
ip dhcp pool DESK
   lease 0 12
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2  1
mls qos srr-queue input cos-map queue 1 threshold 3  0
mls qos srr-queue input cos-map queue 2 threshold 1  2
mls qos srr-queue input cos-map queue 2 threshold 2  4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3  3 5
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3  32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3  5
mls qos srr-queue output cos-map queue 2 threshold 3  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3  2 4
mls qos srr-queue output cos-map queue 4 threshold 2  1
mls qos srr-queue output cos-map queue 4 threshold 3  0
mls qos srr-queue output dscp-map queue 1 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3  48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3  56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3  16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3  32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1  8
mls qos srr-queue output dscp-map queue 4 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3  0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause unicast-flood
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery interval 1000
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
description switch02-ZONE1
switchport mode trunk
switchport nonegotiate
interface Port-channel2
description switch03-ZONE2
interface Port-channel3
description switch04-ZONE3
interface Port-channel4
description switch05-ZONE4
interface Port-channel5
description switch06-ZONE5
interface Port-channel6
description switch07-ZONE6
interface FastEthernet0
ip address 10.100.3.33 255.255.192.0
interface GigabitEthernet1/0/1
description INTERCO
switchport access vlan 100
switchport mode access
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust cos
auto qos voip trust
spanning-tree portfast
interface GigabitEthernet1/0/2
description bridge VLAN4-VLAN1
no cdp enable
spanning-tree bpdufilter enable
interface GigabitEthernet1/0/3
switchport access vlan 4
no cdp enable
interface GigabitEthernet1/0/4
description Module Management Blade 1
no cdp enable
interface GigabitEthernet1/0/5
shutdown
no cdp enable
interface GigabitEthernet1/0/6
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/7
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/8
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/9
description Ethernet SM 1 - Blade
no cdp enable
interface GigabitEthernet1/0/10
description Ethernet SM 2 - Blade
no cdp enable
interface GigabitEthernet1/0/11
description Router SFR
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/12
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/13
switchport voice vlan 5
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/14
description Printer ZEBRA
switchport access vlan 3
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/15
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/16
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/17
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/18
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/19
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/20
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/21
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/22
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/23
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/24
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/25
queue-set 2
mls qos trust cos
auto qos voip trust
channel-group 1 mode on
interface GigabitEthernet1/0/26
queue-set 2
mls qos trust cos
auto qos voip trust
channel-group 5 mode on
interface GigabitEthernet1/0/27
queue-set 2
mls qos trust cos
auto qos voip trust
channel-group 2 mode on
interface GigabitEthernet1/0/28
queue-set 2
mls qos trust cos
auto qos voip trust
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface GigabitEthernet2/0/1
description Router SDSL_2M
interface GigabitEthernet2/0/2
description description ServerD
switchport access vlan 20
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/3
description temp D
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/4
description Firewall D
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/5
description Video
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/6
description Video
switchport access vlan 6
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/7
description Video
interface GigabitEthernet2/0/8
description Video
interface GigabitEthernet2/0/9
no cdp enable
interface GigabitEthernet2/0/10
speed 10
no cdp enable
interface GigabitEthernet2/0/11
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
macro description cisco-desktop
spanning-tree bpduguard enable
interface GigabitEthernet2/0/12
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/13
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/14
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/15
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/16
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/17
speed 10
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/18
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/19
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/20
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/21
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/22
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/23
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/24
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/25
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/26
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/27
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/28
queue-set 2
mls qos trust cos
auto qos voip trust
channel-group 6 mode on
interface TenGigabitEthernet2/0/1
interface TenGigabitEthernet2/0/2
interface GigabitEthernet3/0/1
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/2
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/3
description BICS Port1
switchport access vlan 5
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/4
description GD
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/5
description Qcom
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/6
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/7
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/8
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/9
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/10
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/11
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/12
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/13
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/14
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/15
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/16
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/17
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/18
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/19
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/20
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/21
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/22
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/23
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/24
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/25
queue-set 2
mls qos trust cos
auto qos voip trust
channel-group 3 mode on
interface GigabitEthernet3/0/26
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet3/0/27
queue-set 2
mls qos trust cos
auto qos voip trust
channel-group 4 mode on
interface GigabitEthernet3/0/28
queue-set 2
mls qos trust cos
auto qos voip trust
interface TenGigabitEthernet3/0/1
interface TenGigabitEthernet3/0/2
interface GigabitEthernet4/0/1
shutdown
interface GigabitEthernet4/0/2
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/3
description BICS Port2
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/4
description CS-b Backup
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/5
description GA
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/6
description standard
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/7
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/8
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/9
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/10
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/11
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/12
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/13
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/14
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/15
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/16
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/17
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/18
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/19
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/20
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/21
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/22
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/23
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/24
description phone ext
switchport port-security mac-address 0080.9f7e.46e1
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/25
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/26
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/27
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet4/0/28
queue-set 2
mls qos trust cos
auto qos voip trust
interface TenGigabitEthernet4/0/1
interface TenGigabitEthernet4/0/2
interface Vlan1
description OLD_LAN
ip address 192.168.1.254 255.255.255.0
interface Vlan2
description DESK
ip address 10.56.2.254 255.255.255.0
interface Vlan3
description PROD
ip address 10.56.3.254 255.255.255.0
interface Vlan4
description MGMT
ip address 10.56.4.254 255.255.255.0
interface Vlan5
description VOIP
ip address 10.56.5.254 255.255.255.0
interface Vlan6
description VIDEO
ip address 10.56.6.254 255.255.255.0
interface Vlan10
description SHP
ip address 10.56.11.254 255.255.255.192
interface Vlan20
description D
ip address 10.56.20.254 255.255.255.0
interface Vlan100
description INTERCO-INTERNET
ip address 10.56.100.254 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.56.100.1
ip route 10.56.10.0 255.255.255.0 10.56.11.253
ip route 10.56.11.160 255.255.255.224 10.56.11.253
ip route 10.100.0.0 255.255.0.0 192.168.1.253
ip route yy.yyy.yyy.yyy 255.255.255.255 10.56.100.1
ip route 172.20.31.0 255.255.255.0 192.168.1.253
ip route 172.20.32.0 255.255.255.0 192.168.1.253
ip route 192.168.200.0 255.255.255.0 10.56.20.240
ip http server
control-plane
line con 0
login local
line vty 0 4
login local
length 0
transport input telnet
line vty 5 15
login local
ntp clock-period 36026709
ntp server 194.2.0.28
end
Recognize Your Peers
