DHCP Binding Issue - Help!!! :/
maback
Community Member
I am having issues with getting clients to obtain a static DHCP binding which I have applied on the site Core switch (also acting as the site DHCP server).
CoreSwitch#show run
ip dhcp pool xxxx
network 10.100.1.0 255.255.255.0
default router 10.100.1.1
domain-name xxxx
dns-server 10.x.x.x 10.x.x.x 8.8.8.8
ip dhcp pool binding_x
host 10.100.1.44 255.255.255.0
client-identifier d4c9.ef50.9e10
client-name x
Troubleshooting steps followed so far:
1. issue a 'clear ip dhcp binding 10.100.1.216' on the the core switch
2. perform an ipconfig /release & /renew on the Windows 7 client laptop
3. reboot the laptop
4. Substituted the 'client-identifer' field with the 'hardware-address' field in the config (and also repeated steps 1-3)
No matter what, the client machine keeps getting the orginal DHCP lease it had before the binding was cleared (10.100.1.216).
Does anyone have any other ideas on how to solve this issue? Thanks!! 🙂
6 Replies 6
Sebastian Helmer
Level 10
Level 10
What Happen if u exclude the IP from the DHCP offer, do he get another one?
cadet alain
do this:
no client-identifier d4c9.ef50.9e10
client-identifier 01d4c9.ef50.9e10
Alain
Hi Sebatsian & Alain,
Thanks for your advice, I've tried both of your suggestions, but it's still not working... the PC is now getting 10.100.1.225 (as opposed to .216)
Any other ideas?
Thanks!
Matt
maback
Community Member
Hi Sebastian & Alain,
I've now figured this out, the configuration appears to require the '01' appended to the start of the MAC address to recognise that the client media type is using an Ethernet controller, without this the DHCP server wasn't recognising the DHCP request from the client.
All working now, thanks for your input! 🙂
Matt
Hi Matt,
This is exactly what I told you to do in my previous reply:
do this:
Alain
Alain
Hi Alain,
Apologies, I did not pick up on that in your initial reply, but yes you are correct!
Thank you.
Matt
