DHCP Pool Options-example Option 47
DELL ACORD
What DHCP options are available when configuring IOS as an DHCP server?
Where can I find the documentation for the available options?
Thanks in Advance.
DTA
2 Accepted Solutions
cadet alain
I think all rfc2131 options can be configured.I don't know of any single document  explaining the different options.
For syntax see here: http://www.cisco.com/en/US/docs/ios/12_0t/12_0t1/feature/guide/Easyip2.html#wp21566
Regards.
Alain.
RFC 2132 and RFC 3679(unused DCHP option codes) can be checked.
For a list by IANA check
http://www.iana.org/assignments/bootp-dhcp-parameters/bootp-dhcp-parameters.xml
Alex
cadet alain
Regards.
Alain.
Alex
