DHCP SCOPE OPTIONS
Tree1964
I'm hoping someone can help me with this.  I'm trying to change the SIP server IP Address under the scope options (option 120) for NEC-Voip.  When I right click on "Scope Options -> Configure Options -> Advanced -> then choose NEC-VoIP for vendor class how do I edit the Data entry?   I know what the hexidecimal to decimal should be but it doesn't allow me to enter the new values
Thanks for any help in advance.
Mark Elsen
             - What brand of dhcp server are you using ?
 M.
It’s a Windows Server 2016
M02@rt37
Hello @Tree1964,
Do you have the necessary permissions to edit it ? Do you try to edit another field? same problem?
Best regards
Yes, I have permissions and it’s the same for all fields.
