DHCP Snooping- PCs are not taking IP address after enabling DHCP snooping
Ramz PV
    I have enabled DHCP snooping in our network. but after enabling the same, User machines are not getting IP address from DHCP server. I have attached the network diagram with all details. kindly assist me to sort out this issue.
6 Replies 6
Hello
Are you trusting also the interfaces towards your dhcp server?
Is DHCP option 82 enabled?
check by:
sh ip dhcp snooping
If this is enabled then try trusting dhcp relay on those interfaces
int x/x
ip dhcp relay information trusted
res
Paul
Kind Regards
Paul
Hi Paul,
       Option 82 is enabled. I have configured "ip dhcp snooping trust" on all the trunk interfaces. please note that dhcp snooping is not enabled in the server farm switches where DHCP server is connected.
Ramith
What IOS version is running on the access switch? Some version of 15.0  have broken dhcp snooping.
John
**Please rate posts you find helpful**
Hi John,
    IOS Version 12.2(55)SE8 is running in my 3560 access switches.
Ramith
Hi all,
    I have tried "ip dhcp relay information trusted" and "no ip dhcp snooping information option" and still the PCs are not getting IP address from DHCP server. but as soon as I remove dhcp snooping command from the switch, it started working. please help.
FYI : All the PCs are connected through AVAYA phones and the access interfaces are configured with Access vlan and Voice vlan.
Harrie Hendriks
We have a Microsoft DHCP server and we are not using option 82.
Regards Harrie
