DHCP snooping Static binding ?
Hey Guys
have an issue with dhcp snooping static binding. any help appreciated.
i have 3850's , and for some reason ARP ACL's dont work. we added static dhcp snooping entries, and works great.
1) ip dhcp snooping binding x.x.x.x command
2) user is in snooping database, and it is pushed to ftp server - works great
3) issue is when the switch reboots - the static entry is gone from the switch after the switch comes up.. ftp server has the entry, but the switch downloads all snooping bindings, except the static entries
4) after write delay, the switch writes the existing db -without static entries, and the FTP server gets the DB updated ..
now all static users are gone.. We have to manually add entries back to make it work.. or do a renew ip dhcp snooping database before the delay write timer expires..
Any solution for static users ?
michaelmaeda
The static entries should be saved in the switch configuration. Do you see them shown in the running configuration? Have you saved them to the startup configuration?
