DHCP snooping with DAI issues
vlad0
Hello, I have som problem with DHCP snooping working with DAI. Can anyone explain to me, why I am getting those invalid ARP req?
ARP inspection is configured like this:
Source Mac Validation      : Enabled
Destination Mac Validation : Disabled
IP Address Validation      : Enabled
I set arp inspection limit rate to 25. but this value was pretty low, so I rised it up to 50. It was a way better, but there were still some errdisable ports due to much arp req, so I set it to 100. When I rised it to 100pps, I was getting much more errdisabled ports, like when I had it at 50. Can anyone explain this behavior?
8 Replies 8
Ton V Engelen
Level 3
Level 3
Check the logs on your switches to see if the rate limit is exceeded on the ports that are err-disabled
If its set to 100 there probably will be logs stating the limit is exceeded by 101 requests
In the end I have set the rate limit to 250 which solved the issue.
Esp. Apple computers fire arp like crazy
because I red some articles and they said rate limit should be set max to 100, but I still had problem with exceeded rate limit, so I decided to ask for a help. So, is it normal? I have never done configuration about DAI, so I am pretty new at it. will I try to rise it up in increment of 25? so I try to set it up to 125.
We have windows 7 only (I read that LLPD is responsible for generating much ARP req because of discovery devices on network)
Second question: Why am I getting those invalid ARPS?
%SW_DAI-4-INVALID_ARP: 1 Invalid ARPs (Res) on Fa0/19, vlan 40.([9c93.4e65.5927/10.1.43.81/9c93.4e65.5927/10.1.43.81/13:24:35 CET Tue Dec 12 2017])
output from DHCP snooping bind table
9C:93:4E:65:59:27   10.1.43.81       600852      dhcp-snooping   40    FastEthernet0/19
But I am still able to reach 10.1.43.81, can u pls explain this behavior?
I d just set it to 250 right away
Or start with 150 and increase with steps of 25.
About the log:
Probably just one or two for each port right?
I see the same thing and I think this is a sort of in between log, while DAI starts operating for that port
After the mapping (port/mac/ip) is build all is fine and the device on that port is reachable
Hello
Where is the location of the dhcp server?
DAI/snooping should be only applied on the access layer switches, do you have dhcp service and snooping enabled on the L3 switch by any chance?
res
Paul
Kind Regards
Paul
DAI is sometimes a pain in the butt. Things you need to understand is DAI relies on the DHCP snooping database, which should be offloaded to tftp. Also If you have static addresses you need to create basically a DAI exception list for those statics. Also from a previous environment we have HP printers on DHCP that were crazy with ARP requests so we had to increase the limit on a per port basis.
Hi, DHCP server is located on another subnet where L3 switch points to DHCP as dhcp helper.
DHCP snooping and ARP inspection is configured only on access switches, where trunks links pointing to DHCP are configures as trust ports.
thx for advise, I am going to experiment with rates limits of arp inspection. I will let u know about results.
//for now my dhcp snooping database is located in flash memory. I will move it later to tftp
//we have some devices which have static addresses becasuce of lack of DHCP services, but I did bind them manualy do dhcp snooping database by "ip dhcp snooping binding xxxxxx" command
I set arp inspection limit rate to 200 and everything runs smoothly, no err-disabled ports. I was just affraid of so "high" value, cuz sa I said i read it should be set the lower value as possible eg 25pps. Anyway, thx for your assistance guys
Super!!
