Dial Peer Setup for CME
benjaminkamau
Hi Team,
I have the below setup on a 2921 router running CME;
2 GSM gateways connected to the router's VIC FX0 ports. (072....... & 073.......)
Internal extensions start with 2001 onwards
I would like assistance on how to configure dial peers to allow the GSM lines to call directly to extension 2001 (reception) and vice versa.
Ben
post the config you currently have...
Hi George,
See below configs
I have not yet configured the dial peers since I have limited knowledge in that topic.
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp excluded-address 192.168.1.178
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool VOICE
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
option 150 ip 10.10.10.1
ip dhcp pool DATA
network 192.168.1.0 255.255.255.0
default-router 192.168.1.178
dns-server 5.11.11.11 5.11.11.12
ip dhcp pool WIRELESS
network 192.168.0.0 255.255.255.192
default-router 192.168.0.1
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice translation-rule 1
voice translation-profile INCOMING-PSTN
translate calling 1
license udi pid CISCO2921/K9 sn
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WAN
ip address 41.x.x.x 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 10.10.10.1 255.255.255.0
ip helper-address 192.168.1.9
interface GigabitEthernet0/1.50
encapsulation dot1Q 50
ip address 192.168.1.178 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.60
encapsulation dot1Q 60
ip address 192.168.0.1 255.255.255.192
ip nat inside
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAME interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 41.X.X.X
ip access-list extended NAME
permit ip 192.168.100.0 0.0.0.255 any
permit ip 192.168.1.0 0.0.0.255 any
permit ip 192.168.0.0 0.0.0.63 any
tftp-server flash:term41.default.loads alias term41.default.loads
tftp-server flash:apps41.8-5-3TH1-6.sbn alias apps41.8-5-3TH1-6.sbn
tftp-server flash:cvm41sccp.8-5-3TH1-6.sbn alias cvm41sccp.8-5-3TH1-6.sbn
tftp-server flash:dsp41.8-5-3TH1-6.sbn alias dsp41.8-5-3TH1-6.sbn
tftp-server flash:jar41sccp.8-5-3TH1-6.sbn alias jar41sccp.8-5-3TH1-6.sbn
tftp-server flash:SCCP41.8-5-3S.loads alias SCCP41.8-5-3S.loads
tftp-server flash:apps41.8-4-1-23.sbn alias apps41.8-4-1-23.sbn
tftp-server flash:cnu41.8-4-1-23.sbn alias cnu41.8-4-1-23.sbn
tftp-server flash:cvm41sccp.8-4-1-23.sbn alias cvm41sccp.8-4-1-23.sbn
tftp-server flash:dsp41.8-4-1-23.sbn alias dsp41.8-4-1-23.sbn
tftp-server flash:jar41sccp.8-4-1-23.sbn alias jar41sccp.8-4-1-23.sbn
tftp-server flash:SCCP41.8-4-2S.loads alias SCCP41.8-4-2S.loads
tftp-server flash:apps45.9-1-1TH1-16.sbn alias apps45.9-1-1TH1-16.sbn
tftp-server flash:cnu45.9-1-1TH1-16.sbn alias cnu45.9-1-1TH1-16.sbn
tftp-server flash:cvm45sccp.9-1-1TH1-16.sbn alias cvm45sccp.9-1-1TH1-16.sbn
tftp-server flash:dsp45.9-1-1TH1-16.sbn alias dsp45.9-1-1TH1-16.sbn
tftp-server flash:term65.default.loads alias term65.default.loads
tftp-server flash:jar45sccp.9-1-1TH1-16.sbn alias jar45sccp.9-1-1TH1-16.sbn
tftp-server flash:SCCP45.9-1-1SR1S.loads alias SCCP45.9-1-1SR1S.loads
control-plane
voice-port 0/1/0
connection plar opx 100
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
caller-id enable
voice-port 0/2/0
caller-id enable
voice-port 0/2/1
caller-id enable
voice-port 0/2/2
caller-id enable
voice-port 0/2/3
description == md ==
mgcp profile default
gatekeeper
shutdown
telephony-service
max-ephones 100
max-dn 200
ip source-address 10.10.10.1 port 2000
timeouts ringing 20
system message
cnf-file location flash:
load 7916-12 B0I6-1-0-4.SBN
load 7911 SCCP11.8-5-3S.loads
load 7941 SCCP41.8-4-2S
load 7965 SCCP45.9-1-1SR1S
time-zone 31
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 May 14 2018 09:00:49
ephone-template 1
softkeys hold Resume Newcall
softkeys idle Redial Newcall Cfwdall Dnd
softkeys seized Endcall
softkeys alerting Endcall
softkeys connected Hold Endcall Trnsfer Confrn
softkeys ringing Answer Dnd
max-calls-per-button 2
type 7911
ephone-dn 1
number 2005
name IT
ephone-dn 2
number 2003
name Deputy RD
ephone-dn 3
number 2009
name Library
ephone-dn 4 dual-line
number 2008
name Accountant
ephone-dn 5
number 2011
name R.O L
ephone-dn 6
number 2004
name P.A R
ephone-dn 7 dual-line
number 2015
name Se
ephone-dn 8
number 2001
name Reception
ephone-dn 9 dual-line
number 2017
name Admin
ephone-dn 10 dual-line
number 2018
name Reg
ephone-dn 11
number 2002
name ReS
ephone-dn 14 dual-line
number 2014
name For
ephone-dn 19 dual-line
number 2019
name R.O K
ephone-dn 20
number 2020
name KA
ephone-dn 21 dual-line
number 2021
name KB
ephone-dn 22 dual-line
number 2022
name KC
ephone-dn 23 dual-line
number 2023
name KD
ephone-dn 24 dual-line
number 2024
name R.O Lydia
ephone-dn 25 dual-line
number 2025
name Int
ephone-dn 27
number 2027
name R.
ephone-dn 28
number 2028
name R.O
ephone-dn 29
number 2029
name Ca
ephone 1
device-security-mode none
mac-address X.X.X
button 1:1
ephone 2
mac-address X.X.X
button 1:2
ephone 3
mac-address X.X.X
button 1:3
ephone 4
mac-address X.X.X
button 1:4
ephone 5
mac-address X.X.X
button 1:5
ephone 6
mac-address X.X.X
button 1:6
ephone 7
mac-address X.X.X
button 1:7
ephone 8
mac-address X.X.X
button 1:8
ephone 9
mac-address X.X.X
button 1:9
ephone 10
mac-address X.X.X
button 1:10
ephone 11
mac-address X.X.X
button 1:11
ephone 14
mac-address X.X.X
button 1:14
ephone 19
mac-address X.X.X
button 1:19
ephone 20
mac-address X.X.X
button 1:20
banner motd ^C^C
line con 0
password kefriI23coast
logging synchronous
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
logging synchronous
login
transport input all
scheduler allocate 20000 1000
end
2921 Router#sh telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 100
max-dn 200
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: flash:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
timezone 31 Saudi Arabia Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 20
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message
web admin system name Admin
web admin customer name Customer
edit DN through Web: disabled.
edit TIME through web: disabled.
background save interval 10 minutes
Log (table parameters):
max-size: 150
retain-timer: 15
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
2921 Router#
