dial up issues
carl_townshend
Hi all, has anyone come across this issue, we are dialling up to a vpn using analogue dial, (phone number), this works from our office, and the user can make voice calls from her phone at home, but it will not let her dial up to the number at home, can isp's such as bt etc block data traffic over the pstn line ?
bjornarsb
Level 4
Level 4
You need to post some of your config, if we're supposed to help you.
Do you use: modem InOut (Configure line for incoming AND outgoing use of modem)
BR,
Bjornarsb
