10-16-2011 07:19 AM - edited 03-07-2019 02:49 AM
hello
in addition to the Line Card Slot Speed,
what is the difference between the Catalyst 4507R+E Switch and Catalyst 4507R-E Switch
Thanks you
Solved! Go to Solution.
10-16-2011 08:07 AM
Maurice
The additional bandwidth per slot is the only real difference between the 2 chassis _
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/qa_c67_610073.html
Jon
10-16-2011 08:07 AM
Maurice
Jon
10-16-2011 08:22 PM
Adding to Jon. Please also bear in mind the minimal SW requirments for both chassis. Those are slightly different.
Nik
