Difference between slavedisk0 and slavesuo-bootdisk
mahesh18
Level 6
Level 6
hI,
Switch 6509 which is IOS  based has has sup 32 what is difference between commands
dir slavedisk0   and   dir  :  slaveboot-flash  and   slavesup-bootdisk: )
if someone can explain me this please?
many thanks
mahesh
Jerry Ye
Assuming you have dual SUP in your chassis and I will assume you know what is the different between SP (switch processor) and RP (route processor).SP is a.k.a. SUP, where RP is a.k.a. MSFC.
On the active SUP:
disk0: - the CF card slot in the SUP
bootflash: - flash memory on the RP
sup-bootdisk: or sup-bootflash: (depend on the version) - flash memory on the SP
For Standby SUP, add the slave keyword in front of the above memory space. Like slavedisk0: is the CF card slot on the standby SUP.
HTH,
jerry
Jerry Ye
On the active SUP:
HTH,
jerry
Hi jeye,
Many thanks  for the excellent reply.
mahesh
