06-03-2015 07:19 AM - edited 03-08-2019 12:20 AM
Hi everybody,
I have a ME 6524 (ME-C6524GT-8S) and I need to connect it to an ASR 1002 using a GigaEth copper link. I still have some unused dowlink port (these are 10/100/1000 ports) but I haven't any SFP available in the uplink ports; so I wondering if there is any reason to equip an uplink port with a new SFP instead of using an available downlink port. Anybody can help me?
enrico
06-03-2015 08:41 AM
You can certainly use one of the copper ports if you don't want to purchase the SFP and the distance between the 2 devices is less than 100 meters.
06-04-2015 12:20 AM
Thx Sharif, but are you aware of any difference between downlink ports and uplink ports ? Why Cisco distinguish between them if they are all the same ? I suppose that some difference is hide in the switch architecture but I can't find many information . The only document I found is here http://www.cisco.com/c/en/us/products/collateral/switches/me-6524-gs-ethernet-switch/product_data_sheet0900aecd8040657e.html
Difference are listed in Table 3
06-04-2015 12:34 AM
Downlink ports are none line rate. Oversubscription 3:1.
