Actually there are differences between the protocols, for example:
VACL is a mechanism in order to be applied to allow or deny access to specific destination, it will involve specific hosts included on the VLAN or the entire VLAN.
PVLAN, is totally different because it is usually used in order to avoid communication or isolation between hosts of the same network segment, it cannot be achieved using VACL.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
