Highlighted
Beginner
Differences in Nexus 7k supervisor cards
Greetings,
I have Nexus 7000 sup cards side by side in this picture and the injector buttons are different.  I was wondering if they could be 2 different models of Sup cards or have they just changed the ejectors?  I replaced another Sup card last night and it was identical to the one on the right.  I am worried about the differences.
3 REPLIES 3
Highlighted
Hall of Fame Expert
You should be able to compare
You should be able to compare the part numbers between your old sup and the new one.  If they are the same than they probably have changed the injector.
Highlighted
Beginner
I can login that is for sure
I can login that is for sure but what is up with the hardware difference?
Highlighted
Beginner
They both show Sup 2e's.
They both show Sup 2e's.  Wonder when they changed that because I had issues with pushing it back in the chassis. And minor alarm is still on.
Content for Community-Ad
