Different Module on Different switch?
mamuroloke
Hi need help. if i have CISCO 3750X-12S WITH MODULE GLC-SX MMD on building A and building B WS-C2960-8TC-L WITH UPLINK MODULE 1000BASE-SX can i still connect with out a problem using MMF? suggestion much appreciated, many thanks
Reza Sharifi
Sure, as long as you meet the distance limitation of multimode cable, you are fine.  You need LC to LC connector on both sides.
1000BASE-SX SFP for Multimode Fiber Only
The 1000BASE-SX SFP, compatible with the IEEE 802.3z 1000BASE-SX standard, operates on legacy 50 μm multimode fiber links up to 550 m and on 62.5 μm Fiber Distributed Data Interface (FDDI)-grade multimode fibers up to 220 m. It can support up to 1km over laser-optimized 50 μm multimode fiber cable.
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html
Reza Sharifi
many thanks such a good help for me...
