Disabling keepalive in switch
Jerald Simon M.
         If i am disabling keepalive in switch port , is it  create any issue on network.
below issue we are facing....
connectvity :- 2 access layer switch connecting to 1 normal server
error : below loggs i m  getting on one of the switch and both switch interface going down (errordisable)
%ETHCNTR-3-LOOP_BACK_DETECTED: Keepalive packet loop-back detec
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernetx/x
is there any solution for this ?, most of the forum saying disable keepalive in interface level and check physical cabling part.
InayathUlla Sharieff
https://supportforums.cisco.com/docs/DOC-3876
  http://raabadnetworking.blogspot.in/2010/01/ios-ethcntr-3-loopbackdetected.html
IOS: %ETHCNTR-3-LOOP_BACK_DETECTED : Keepalive packet loop-back detected on [chars]
Description
The problem occurs because the keepalive packet is looped back to the port that sent the keepalive. Keepalives are sent on the Catalyst switches in order to prevent loops in the network. Keepalives are enabled by default on all interfaces. You see this problem on the device that detects and breaks the loop, but not on the device that causes the loop.
Workaround
Issue the
no keepalive
interface command in order to disable keepalives. A disablement of the keepalive prevents errdisablement of the interface, but it does not remove the loop.
Permanent Fix
In Cisco IOS Software Release 12.2(x)SE-based releases and later, keepalives are not sent on fiber and uplink interfaces by default. Upgrading the IOS version to this or later images should prevent the above issue in the first place.
