03-27-2018 08:44 AM - edited 03-08-2019 02:25 PM
If i use vrf specific DNS servers in my configuration, it works fine with the ping command:
roTST01#show running-config | include name- ip name-server vrf DSL 8.8.8.8 ip name-server vrf DSL 8.8.4.4 ip name-server vrf LAN 172.16.222.50 ip name-server vrf LAN 172.16.222.52 roTST01#ping vrf DSL www.google.ch Translating "www.google.ch"...domain server (8.8.8.8) [OK] Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.217.16.131, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 24/26/28 ms roTST01#ping vrf LAN swtst01.company.local Translating "swtst01.company.local"...domain server (172.16.222.50) [OK] Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.16.220.3, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
But if i want to use SSH to connect to a device, IOS somehow wants to use the DNS servers that have been assigned to the router via a dialer interface instead of using the ones configured for this vrf:
roTST01#ssh -vrf LAN -l user12 swtst01.company.local Translating "swtst01.company.local"...domain server (195.186.4.162) (195.186.1.162) % Unknown command or computer name, or unable to find computer address
This is a C897VA-K9 with IOS version 15.6(2)T1 if anyone wants to know. Is there something I am missing?
03-28-2018 06:38 AM
03-28-2018 08:20 AM
Hey there, thanks for the reply. I did not change anything with ip domain-lookup which means, it is still in its IOS default state, which means activated. I configured the source interface command as suggested, but it did not help:
roTST01(config)#ip domain-lookup source-interface vlan 10
roTST01(config)#end roTST01#show running-config interface vlan 10 Building configuration... Current configuration : 175 bytes ! interface Vlan10 description Company Net ip vrf forwarding LAN ip address 172.16.220.2 255.255.255.0 ip helper-address global 172.16.200.10 ip tcp adjust-mss 1366 end roTST01#ssh -vrf LAN -l user12 swtst01.company.local Translating "swtst01.company.local"...domain server (195.186.4.162) (195.186.1.162) % Unknown command or computer name, or unable to find computer address
Even if this workaround would help, i would limit the usage of the ssh domain lookup to only one vrf (the one that interface vlan10 is assigned to). In a correct implementation, the SSH command would contact the DNS servers that are responsible for the specified VRF to resolve names.
