DNS Problem
amidoufloriantoure1
Community Member
Hi all I'm working on an NAC solution which is PacketFence but I'm unable to access to the internet:I got the error the dns is responding.
-The NAC solution is installed on a Centos 6.7 machine no DNS there
-The user authenticates using a Cisco 3560 Series configured as a layer 2 switch.the switch can access to the internet
-Finally we have a Cisco 2600 series connected to the internet.The DNS seems to work on the router but not from the authenticate user ,here is the configuration of the router :
Current configuration : 1759 bytes
version 12.2
service password-encryption
hostname Router2600
enable password 7 05080F1C2243
ip subnet-zero
ip domain lookup source-interface FastEthernet0/1
ip name-server 8.8.4.4
ip name-server 8.8.8.8
voice call carrier capacity active
mta receive maximum-recipients 0
interface FastEthernet0/0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0.1
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 192.168.40.1 255.255.255.0
interface FastEthernet0/0.60
encapsulation dot1Q 60
ip address 192.168.60.1 255.255.255.0
interface FastEthernet0/0.80
encapsulation dot1Q 80
ip address 192.168.80.1 255.255.255.0
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
ip address 10.1.95.180 255.255.0.0
ip nat outside
duplex auto
speed auto
interface Ethernet1/0
no ip address
shutdown
half-duplex
ip nat inside source list NAT_TRAFFIC interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.254.254
no ip http server
ip access-list extended NAT_TRAFFIC
permit ip 192.168.0.0 0.0.255.255 any
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
password 7 104D000A0618
login
line aux 0
line vty 0 4
password 7 00071A150754
login
end
Francesco Molino
With your NAC solution, which vlan are provisioned to users? Who is doing DHCP?
Your router is not doing DHCP and then it will not be the point of failure of your DNS issues.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
