09-08-2015 01:59 PM - edited 03-08-2019 01:41 AM
Hello friends,
Does the Cisco 2960X specifically WS-C2960X-48LPS-L comes with stack module and cable in the box or do we need to order it separately? It costs nearly $1,000 for one stack module which ships with 0.5m stack cable. The SKU for stack module which can be ordered for 2960 is C2960S-STACK=
Does Cisco ship stack module and cable with the switch or not?
Rushabh
09-08-2015 02:42 PM
The stack-module is optional and has to ordered additionally if you need it.
09-08-2015 02:53 PM
Thanks Karsten Iwen for your reply. I understand it's optional to order but I wanted to know if there is any stacking cable / module which comes built in? Is there module/cable shipped with the box or not?
09-08-2015 03:01 PM
No, it's not. You have to order it if you need it.
09-09-2015 08:52 AM
Do you know if SFP-H10GB-ACU10M or SFP-H10GB-CU5M will work with Catalyst WS-C2960X-48LPS-L or not for Stacking purposes? The FlexStack module is very expensive for Catalyst 2960 and was wondering if I can use the same SFP twinax cables for stacking purposes on Catalyst 2960. Will the configuration remain the same on the Catalyst or will it be different?
Thank you!
09-09-2015 09:09 AM
Stacking is only done with the stack-module. If you want a less expensive solution that can stack with 10Gig Twinax-cable, the SG500X is for you.
