01-06-2015 11:16 PM - edited 03-07-2019 10:07 PM
Ouput of show version on Cisco 3850
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.03.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 23-Sep-13 18:24 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
--More--
Cessana_Core_Switch uptime is 1 week, 3 days, 21 hours, 37 minutes
--More-- Uptime for this control processor is 1 week, 3 days, 21 hours, 40 minutes
System returned to ROM by reload
--More-- System image file is "flash:packages.conf"
Last reload reason: Reload command
--More--
--More--
--More-- States and local country laws governing import, export, transfer and
--More-- third-party authority to import, export, distribute or use encryption.
--More-- compliance with U.S. and local country laws. By using this product you
--More-- to comply with U.S. and local laws, return this product immediately.
--More-- A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More--
--More-- export@cisco.com.
--More-- License Level: Ipbase
License Type: Permanent
--More-- Next reload license Level: Ipbase
--More-- cisco WS-C3850-24T (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1836U030
--More-- 5 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
--More-- 8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
--More-- 4194304K bytes of physical memory.
257008K bytes of Crash Files at crashinfo:.
--More-- 257008K bytes of Crash Files at crashinfo-2:.
1550272K bytes of Flash at flash:.
--More-- 1550272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0:.
--More-- 0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of at webui:.
--More--
Base Ethernet MAC Address : 68:99:cd:11:b8:80
--More-- Motherboard Assembly Number : 73-14443-07
Motherboard Serial Number : FOC18345NLY
--More-- Model Revision Number : Q0
Motherboard Revision Number : A0
--More-- Model Number : WS-C3850-24T
System Serial Number : FOC1836U030
--More--
--More-- Switch Ports Model SW Version SW Image Mode
--More-- 1 32 WS-C3850-24T 03.02.03.SE cat3k_caa-universalk9 INSTALL
2 32 WS-C3850-24T 03.02.03.SE cat3k_caa-universalk9 INSTALL
--More--
--More-- Switch 02
--More-- Switch uptime : 1 week, 3 days, 21 hours, 40 minutes
Base Ethernet MAC Address : 68:99:cd:6c:27:00
Motherboard Serial Number : FOC18352L19
System Serial Number : FCW1836C075
--More--
Configuration register is 0x102
--More--
Does any body knows whether device will support policy based routing ? I tried configuring the PBR and i have created the route-map, but i am not able to apply it to SVI. Does any body knows the command
As you can see license is IP Base
01-06-2015 11:50 PM
I believe PBR is an exclusive domain of a router.
01-07-2015 12:00 AM
HI Leo,
PBR is supported on Cisco 3850 switch. My confusion is regarding Licensing. In datasheet it's mentioned for PBR, IP services is required and on Cisco 3850 Q &A, PBR is mentioned in IP Base license.
You can refer the datasheets url is http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/data_sheet_c78-720918.html
01-07-2015 12:39 AM
Thanks for the correction. :)
Try upgrading to a higher IOS-XE level, like 3.6.X?
03-11-2015 10:47 PM
Hi Mahesh,
Did you upgrade IOS, we did and it worked..so definitely an issue with 03.02.03.SE
