does Cisco C9300-NM-8X work in C3850-12X48U?
Mikhail Faifman
Beginner
Beginner
I understand that C3850-NM-8-10G works in C9300 switches. Does this mean that C9300-NM-8X will work in C3850-12X48U?
The cost of C9300-NM-8X is 50% vs the cost of C3850-NM-8-10G.
Thank you.
marce1000
 - Negative = ref : https://www.cisco.com/c/en_in/products/collateral/switches/catalyst-3850-series-switches/datasheet_c78-720918.html
                            Check Table 2
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
marce1000
                            Check Table 2
 M.
yes, i read that document and was hoping that with time 9300 card will make it
The C9300 switch didn't exist when table 2 in that spec sheet for the 3850 was written. So, none of the 9300 compatible parts are listed. We just tested a C9300-NM-4G here and it  worked fine in a 3850. Maybe the C9300-NM-8X does too?
carlos.rosa1
Beginner
Beginner
Observação: os módulos de rede Catalyst 3850 e Catalyst 9300 são suportados nos modelos Catalyst 9300. Os módulos de rede Catalyst 9300X são suportados apenas nos modelos Catalyst 9300X.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
