I would like to use IP SLA with icmp echo on a managed layer 2 switch
thanks
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As far as I know, if ping works between hosts, so should IP SLA.
so no need to enable ip routing?
Again, as far as I know, only if you also needed it to make ping work.
ok thanks, i'll give it a try
