Does N9300k FX2 support Per Vlan Statistics? Im not able to see the counters on VLAN interface.
r.aneeshc
Beginner
Beginner
I'm having an issue with identifying the traffic load on Vlan interface on my N9k FX2 (specifically C93360YC-FX2).. Show interface Vlan XXX displays with the traffic shown as :- ucast: 0 pkts, 0 bytes. Please can someone explain if this is expected behaviour or not?
Many thanks in advance.
Sergiu.Daniluk
VIP Advisor VIP Advisor
VIP Advisor
Seems like not, due to following bug: https://quickview.cloudapps.cisco.com/quickview/bug/CSCvp32970
Symptom:
SVI counters do not work on N9K-C93240YC-FX2 even with "hardware profile svi flex-stats-enable" applied.
Known Affected Releases
9.2(3) 9.3(1)
Sergiu
5 Replies 5
Reza Sharifi
Hall of Fame Expert Hall of Fame Expert
Hall of Fame Expert
Does vlan xxx have an IP associated with? Is the IP the gateway for a user or server vlan traffic?
Thanks, Reza for the response.
Yes, it is having an IP associated (SVI Interface) and used for establishing an eBGP peering having active traffic flow.
********For reference output state as below************
VlanXXX is up, line protocol is up, autostate enabled
Hardware is EtherSVI, address is XXXXX
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
ARP type: ARPA
L3 in Switched:
ucast: 0 pkts, 0 bytes : >>>  This is the part which concern me at this point
Many thanks.
Do you see traffic on the physical interface that is peering BGP? If yes, not seeing traffic on the vlan interface may not be an issue.
Sergiu.Daniluk
VIP Advisor
Symptom:
9.2(3) 9.3(1)
Sergiu
Many thanks, Sergiu for the response and explanation. it really helps.
Recognize Your Peers
