does not execute the command crypto key generate rsa switch 3560G
alexisbonilla84
buenas tardes
tengo este problema al ejecutar el comando crypto key generar rsa
SR-3560G#clave criptográfica generar rsa
% Entrada no válida detectada en el marcador '^'.
2 Accepted Solutions
i dont believe ip base can have that support. check feature navigator.
https://cfnng.cisco.com/
BB
C3560-IPBASE-M
This particular version does not support crypto.
10 Replies 10
balaji.bandi
Depends on IOS code running, you need security image or License to do that
and you need to do that in confg mode
example :
SR-3560G#config t
(config)# cryptographic key generate rsa
BB
the same message persists
and does not give suggestions with the tab
and does not give suggestions with the tab, version of the switch 12.2
This is the error
i would suggest to post - show version (full output here)
I would ask you to try :
config t
BB
IOS version does not support crypto.
khorram1998
This error message is indicating that the command "crypto key generate rsa" is not being recognized by the switch. This could be due to a number of reasons, such as the switch not having the necessary software or licenses to support this command, or the command being typed incorrectly.
It is important to note that the error message is in Spanish, the correct command in English is "crypto key generate rsa"
To troubleshoot this issue, you can try the following steps:
  1. Verify that the switch is running the correct version of software that supports the crypto key generate rsa command.
  2. Make sure that your switch has the required licenses to support the command.
  3. Check that there is no typo in the command, it should be "crypto key generate rsa"
  4. Try to reload the switch and check if the command is working
If the issue persists, please provide more information about the switch model and the version of the IOS running on it. Also, check the release notes for the IOS version you are running to see if there are any known issues or limitations with the crypto key generate rsa command.
All the best,
AK
Switch Ports Model SW Version SW Image
* 1 28 WS-C3560G-24TS 12.2(35)SE5 C3560-IPBASE-M
BB
C3560-IPBASE-M
