10-10-2021 03:21 AM
Hello bros,
I have made the lab in eve-ng with switch cisco image : 186bi_linux_l2-ipbasek9-ms.may8-2013-team_track.bin (my company switch is c2960s v15.2 and radius server 2016
I already done command as like some guys posted in our community but authentication dot1x for client is failed.
Because I no have experience with dot1x port-based before. i also looked at some document of cisco . i saw almost the authentication dot1x is version 2. but my switch is version 3. i don't know whether the have the difference in the configure or not . So i am still felt many confused.
Could you give me a best solution and example configure for this case ?
Many thanks !
Solved! Go to Solution.
10-10-2021 04:43 AM
In the Virtual vIOS give the ability to test for your Dot1x deployment.
In the real what is the configuration you use - what is not working ?
https://www.youtube.com/watch?v=FgRtfpCOlaM
dot1x is version 2. - can you post example config.
10-10-2021 04:43 AM
10-10-2021 06:55 AM
Hi bro,
I already fix my problem. The reason because I hadn't added the AD Certificate role and configured yet and your video is also helpful with me.
Thanks !
