So if I understand you correctly, you are already CCNP certified and at the same time, you have successfully passed the QoS and BGP/MPLS composite exam, is that so?
I believe in that case, you should be CCIP certified as well because either BSCI or ROUTE exams both counted towards the CCIP. However, to remove any doubt, I strongly urge you to log into the Certification Tracking system at http://cisco.com/go/certifications/login and closely examine your current certification status and possibly the exams you still have to pass before earning a particular certification level. This system will tell you exactly which exams are counting towards your certifications and which exams you still have to pass in order to get a particular certification.
Congratulations to earning your certifications, and good luck!
Best regards,
Peter
