Downgrade VSS 6513-E
Ton V Engelen
Level 3
Level 3
i m wondering if anybody knows if i can downgrade the VSS system directy
from 15.2.1SY6 to 15.1.2SY5
Thanks in advance!
Reza Sharifi
Yes, you can downgrade directly but it will need to be done in a maintenance window as it requires a reboot.
Reza Sharifi
thank you very much!  Btw, yes i already planned a window this saturday
