01-04-2018 09:48 AM - edited 03-08-2019 01:18 PM
I'm trying to downgrade a C3650-48PD running cat3k_caa-universalk9.16.03.05 from 16.3.5 to 03.07.05 and cannot do so. I copy the image (cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin) into flash but there is no software install command available. Has anyone run into this issue? This is the first switch I've seen running the newer code.
Solved! Go to Solution.
01-04-2018 12:49 PM
Hi Mark, Thanks for the response. I ended up having to convert the stack from bundle to install mode. I did software expand file flash:cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin to copy the file to all switches in the stack. This created a packages.conf file that I could then use in the boot string. I reloaded and did a software clean. It is now running the 03.07.05E image.
01-04-2018 09:55 AM
01-04-2018 12:49 PM
