Hi Team,
Can anyone help me to understand the process of Downgrading Switch C3650 IOS what will be the steps? can i directly downgrade ?
Solved! Go to Solution.
check the downgrade Procedure on IOS XE 16.12.3a to OLD one, make sure you understand any gotchas.
you like to do bundle or install mode- depends on requirement.
why do you like to downgrade?
I Mean Downgrade from 16.12.3a to 03.07.05E is an intermediate IOS version required?
No, you can go direct to 3.X.X.
Thank you
I suspect due to stability.
I would too if I could.
One of our ASX servers was a having intermitannt connection after an upgrade,
Now working fine after a downgrade.
Downgrading using BUNDLE mode, i.e just change boot variable to .bin file and later convert to INSTALL mode
or
Request platform software package install switch all file flash: ios.bin force new
to downgrade directly in INSTALL mode.
## Make sure to mark post as helpful, If it resolved your issue. ##
