Dram upgrade
kolawole1
I would like to upgrade the dram of my 2801 router to 256 MB.How do i do that?Here is the output of sh ver.
valglinskiy
You need to order additional DIMM module, cisco part number MEM2801-128D= and put it into the router
http://cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/10_hw.html#wp1026137
valglinskiy
Thank you.Can 64MB SODIMM DRAM for the Cisco 2801 fit in the same slot ?
