11-07-2018 04:38 AM - edited 03-08-2019 04:34 PM
Hi All,
Our organisation is planning to implement a new VoIP solution, As a part of it we have been asked to build a suitable QoS configuration to prioritize VoIP traffic.
We have Cisco 4510R+E with SUP8-E for user connectivity and Cisco 6807XL with Sup-2T for core connectivity.
I have seen we can enable Auto Qos in end user port which will trust the default QoS marking. However I am unable to find the command to carry forward the same trust marking over uplink ports (Uplink is configured with port-channel) towards my core. Is there any command or any option to carry the DSCP trust till core switch.
Our connectivity:
End User --> Cisco 4510R+E --(port-channel)--> Cisco 6807-XL --> WAN
Thanks in Advance....
Sid
11-07-2018 04:47 AM
can you post your config ? You need to apply 'auto qos voip trust' to each physical interface participating in the port channel...
11-07-2018 06:01 AM
Hey,
Thanks for the reply...
However it is not accepting command 'auto qos voip trust' in port which is part of port channel.
physical interface config:
interface TenGigabitEthernet5/1
description Link-Core-VS6807-01##VSS##
switchport trunk allowed vlan <vlan no>
switchport mode trunk
switchport nonegotiate
logging event link-status
udld port aggressive
channel-group 1 mode on
ip dhcp snooping trust
Port-Channel Config:
interface Port-channel1
description Trunk-TO-Core-VS6807-01##VSS##
switchport
Command not accepted:
Access_1-SW4510-01(config)#int te5/1
Access_1-SW4510-01(config-if)#auto ?
security-port Configure AutoSecurity
Command which is available:
Access_1-SW4510-01(config-if)#qos trust ?
device trusted device class
extend Extend trust through a connected device
Access_1-SW4510-01(config-if)#qos trust dev
Access_1-SW4510-01(config-if)#qos trust device ?
cisco-phone Cisco IP Phone
cts Cisco-telepresence
ip-camera Cisco video surveillance camera
media-player Cisco Digital Media Player
Access_1-SW4510-01(config-if)#qos trust exte
Access_1-SW4510-01(config-if)#qos trust extend ?
cos CoS value to use for packets from the device
<cr>
Thanks....
11-07-2018 06:04 AM
post the full config of your 4510...
11-07-2018 06:18 AM
Attaching config file.
I am able to apply "auto qos trust" which is generating internal policy-map.
We also have existing policy-map, which we can replace:
policy-map 1P3Q1T
class PRIORITY-QUEUE
priority
police cir percent 30 bc 33 ms conform-action transmit exceed-action drop
class VIDEO-QUEUE
bandwidth percent 20
class CONTROL-QUEUE
bandwidth percent 30
class class-default
dbl
11-07-2018 06:32 AM
Looking at your config, I cannot tell if you have 'qos' enabled globally:
Access_1-SW4510-01-Test(config)#qos
On the interfaces belonging to the port channel, you should be able to configure "qos trust dscp'...
11-07-2018 07:11 AM - edited 11-07-2018 07:13 AM
HI,
I have no option to enable QoS globally. Is there any other command to enable QoS.
Access_1-SW4510-01(config)#qos ?
Global QoS configuration subcommands:
account Additional lengths to be accounted by QoS Features
control-packets Enable QoS on control packets
diffservmib RFC3289 support for QoS policy-maps
preserve Preserve packet header bits
trace QoS trace log settings
Access_1-SW4510-01(config)#qos diffservmib ?
<cr>
Access_1-SW4510-01(config)#mls ?
% Unrecognized command
NUTPS16A03-SW4510-01(config)#mls
...... Thanks
Sid
11-07-2018 07:16 AM
which IOS are you running ? Post the output of 'show ver'...
11-07-2018 07:28 AM
Access_1-SW4510-01-Test#sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.08.06.E RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 05-Apr-18 03:55 by prod_rel_team
ROM: 15.1(1r)SG4
Access_1-SW4510-01-Test uptime is 52 minutes
Uptime for this control processor is 54 minutes
System returned to ROM by reload
System restarted at 14:34:27 GMT Wed Nov 7 2018
System image file is "bootflash:cat4500es8-universalk9.SPA.03.08.06.E.152-4.E6.bin"
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1B9E
Last reload reason: Reload Shelf CLI
License Information for 'WS-X45-SUP8-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4510R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID FXS1749Q1MR
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from Reload
3 Virtual Ethernet interfaces
372 Gigabit Ethernet interfaces
28 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
11-07-2018 08:34 AM
below is the command reference for your IOS and Supervisor. Not all commands are available for each combination:
